ZApplink problems... Please help.
I am having some trouble with ZApplink. When I hit the ZApplink button it opens a few dialog boxes, then opens Photoshop, asks me for a document size and just creates an empty doc. I’m assuming that it should give me an image of some sort… I must be missing something…
Thanks ahead of time for any replies.
sounds like you need to run Zbrush through admin mode.
Thanks… After doing a search I came to that same conclusion. Now my issue seems to be that I can’t
figure out how to configure Zbrush to run in admin mode. The instructions I found only seem to work
for Vista and Win7… I am using Win XP pro with SP3. When I go to the properties for Zbrush, there is no
option to set it to run in admin mode. Any ideas?
Thanks!
Upgrade to an OS made in the last decade?
