Zapplink not working
Hey all, I seem to have a problem using Zapplink when texturing. I’ve been getting really good results using it, but I’m unable to use it at a certain point in my workflow. I’ve tried to use the ‘pickup’ function to see my texture update from Photoshop, it then loads for a short while, but there seems to be no change on the model’s texture. I’ve made sure to use the exact same settings as I was previously using for Zapplink, but still nothing changes. Has this happened to anyone else? I’d really like to get any info I can on this issue, as its a great function and I’d like to keep using it :slight_smile: Thanks in advance!
You mean that in the same ZBrush session, it works, then at a certain stage, it stop working when coming back from Photoshop to ZBrush?
Exactly! So when I return to ZBrush from Photoshop and try to use the ‘pickup’ function, it seems to be loading the update to the texture but no change is made, it just reverts to the previous state.
T0rch, I am having the same issue! What ever changes I make in Photoshop while using ZappLink 4 doesn’t get imported back into the ZBrush session!?! It appears to be for a short while until I press the Pickup button. Then, it reverts to the initial model/tool displayed with no new changes in terms of texture.
It used to work fine with Windows XP but since I changed to Windows 7, I am having some small glitches as well with other features too.
yes I am having exact same problem and im on windows 7
Snake0391,
I was able to correct the situation by uninstalling and reinstalling ZB4 but also made sure not to use a previous CustomUserInterface file (one I had kept as a backup while using XP). Also, redownloaded all of the plug-ins to start from fresh. All of this also corrected the other small glitches I had with ZB4 on windows 7.
Hope this helps!
