hi,
i’ve been using the zapplink for the first time. subdiv my mesh (high res), added new txr (white square), got to photoshop-adjusted my texture on my mesh, saved it in photoshop, got back in zbrush the texture appered on the mesh for a second but then it turn back to white with the message that i can redrop by using the tool- what does it mean? why did it happened? how will i be able to see my adjusted texture from photoshop on my mesh in zbrush? and how can i unwrap the model with the texture on it?
thank you…
I’m not clear what error message you are seeing - can you post a screen shot? Also, if you want to use Photoshop’s 3D capabilities then you can use GoZ to send your model between ZBrush and Photoshop. ZAppLink is quite an old plugin now.
thank you ! not able to take a screen shot of the message cause it’s appears only for a few seconds…
