zapplink not working as expected
When clicking re-enter zb from photoshop to apply the texture, zapplink doesn’t apply the new texture data.
ZB will show texture changes when the ‘zapplink projection’ window comes up (and it looks right), but after pressing accept and running through the different views (fbrltb), the newly created texture is not applied. I’ve tried this with and w/out uv’d objects and success is very sporadic. any one else run into this problem, and a fix perhaps. maybe I’m not setting up my object correctly…
zb4r4, w64, win7.
You should upgrade to 4R4P2.
Oops, left that off the specs.
Just noticed that when I return from PS, my brush settings are changed from rgb to zadd. This may be why no color info is not being set.
Didn’t realize a texture is needed, since I almost always use spotlight now, thought colorize/polypaint would work.
