Hi
I am missing the tool Zapplink in 3.5
Isnt it possible to use this tool in 3.5?
Thanks a lot
Hilmar
The plugins that will work for 3.5 have not yet been released
Richard
Ay! Ok thanks a lot.
Damned.
Havnt known this.
And now I am to far to go back to zbrush 3.1
I just ran into the same problem!
Is there an easy way to uninstall the 3.5 update or do I have to completely reinstall 3.1?
ZB 3.5 doesnt update 3.1…it runs separately. 3.1 should run fine unless you actually uninstalled it for whatever reason. In which case, yes, you’ll have to reinstall it.
Oh very cool, I didnt even notice the separate executable. Thanks for the heads up.
Z brush was already 3.5 when I bought it. so I got the 3.5 download.
therefore I do not have 3.1 form before.
Is there sill a way I can run 3.1 to?
I need to work form concept sketches that are not perfectly side or front view. The image plane X reference setup seems to be no good for this as I can’t find A practical way to try and set it to the same angle as the concept sketches.
Unless some one has a good work around work flow?
Is there way to save a camera view with out Zapplink?
Any help would be mach appreciated.
