Sorry, I found a related thread on this the other day where the proposed solution was a complete uninstall/re-install…i tried that and its still not working, but can’t find that thread to post to it, so i’m starting a new one.
So as the title states, I can't get ZApplink 4 to work in ZB4. So here's what I did:
- fresh install of ZB4
- unpacked the ZApplink4 zsc and folder to the ZStartup/ZPlugs folder
- started ZB and drew a tool on to the canvas
- hit the Document->ZApplink button
- Checked the perspective and fade check boxes (no Colorize option/dialog appears as noted in the manual)
- in PS, i draw on layer 1 and save the file
- back in ZB i hit Re-Enter ZBrush button
- I see the strokes i drew in ZB on my tool at this point
- I hit the Pickup Now button
- ZB4 shows progress for ZApplink at the top left
- the strokes i saw before disappear when progress finishes
in case it matters:
- Mrgb button is pressed
- Poly paint is on
(i tried it with both off as well…no difference)
as mentioned, i tried a complete uninstall and re-install and that hasn’t resolved the issue either.
does anyone have any ideas what might be going on here? I’ve never had this problem in ZB3.5 and ZB4 and ZApplink 4 work fine at home for me (this issue is with my work PC)
my setup:
Dual core i7
6GB RAM
ATI Radeon HD 5700 with latest drivers
running windows 7 pro 64 bit
Thanks!
I think you may have had a different problem there and I hope you found a solution. So frustrating when you need it and it doesn’t work.
