Does anybody knows where to find it?
Thanks
It’s on a development server at Pixologic. You’ll have to don your ninja suit and sneak in through the skylight to get it right now.
Or you can wait for the official release in September or October. The release of v2.5 will be announced around then as well. (repeat; announced).
I think I’ll wait, I am a bit tired for ninjing right now.
I can’t wait for this one. I’ve always wished to use photoshop in conjunction with Zbrush. Yesssss!
you can now…just not in real time like the videos.
load zb and ps up. load your tool/model. load the texture.
now go to ps…load the same texture…do what you will…save it…switch back to zb and viola…see the changes.
have to admit though…using it in pm is gonna rock my socks off!!!
Really? I’ve tried loading a Zbrush texture in Photoshop, but it just looked like a randomly arranged pattern of bitmaps. Is there a way around that without the ZApp plugin?
oops i forgot to mention that it would be hard if your are using uv tiles.
although that i reckon that will still hold with zapplink
to use the feature you would need to use a mapping method other than uvtiles.
Actually, ZAppLink will work perfectly well with any UV mapping – especially a distortion-free method like AUVTiles or GUVTiles.
That’s the beauty of the plugin: There’s no reason anymore to work with an unwrapped view of the texture. You use Projection Master to drop the model to the canvas, and then at any time you can use ZAppLink to send the canvas (not the texture) to Photoshop (or your PSD-capable image editor). There, you can use all the things that Photoshop is best at such as adding text, doing layer effects or applying filters. When you save that document and return to ZBrush, the entire canvas will be updated with the changes made in Photoshop. You can also keep working on the canvas with ZBrush’s tools and features to do all the things that ZBrush is best at. Whenever you’re done, pick the model back up again and continue work like normal.
You can finally be rid of the bad old days when you had to paint on the unwrapped texture and try to manually correct for UV distortions and texture seams. Paint what you want to see, all the time, and let the computer deal with that stuff for you behind the scenes. It’s a much more efficient way to work.
Of course, ZAppLink is useful for more than just texturing. Since you’re sending the canvas to your image editor, that means that you can use the plugin to do whole new things in your illustrations, as well.
Thanks for clearing that up.
woo hoo…that’s even sweeter than I imagined
i love those guvtiles and being able to keep them and being able to use ps has me all a tremblin with anticipation!!
woo hooooooooooooo
if you send the canvas to your image editor then how does the texture show up in your image editor
what if you use the projection master with embed Material
will it restore it after it’s been used in photoshop?
my guess edonkey is that it uses grab doc to create a texture to send to the program then updates the canvas. i think it would need to do this or something similar because your model is dropped in pm. then you pick it up and the changes you made will be applied to your texture. something like that anyways.
edonkey, aurick can correct me if i’m wrong on this but, the work you do in photoshop via ZAppLink will only affect color information and will ignore the embedded materials.
You can actually get a feel for what zapplink will be like right now with the current zbrush. here’s what to do:
get an object on the canvas in edit mode
change your material to flat shader
load up Projection Master (make sure colors is selected, and choose fade if you want)
while in Projection Master, save your canvas document as a .psd
open up photoshop or your psd-capable graphic editor and load the saved canvas document
begin to edit the image; paint on the model. When you’re done, save the .psd
switch back to zbrush. Make sure your material is flat shader and select Document>Import and import the .psd
exit Projection master and examine your results
Start to experiment with this to get different results.
Tip: choose flat shader before entering PM and saving the .psd, otherwise when you import the photoshopped .psd and exit pm, the shading information that the zbrush rendering engine does will be applied to the texture as color information.
ZAppLink basically does all the exporting and material applying for your through a dialogue box so you don’t have to. It also has some other goodies too though.
wauw cool I can’t wait
If you people wanna see how it works. There is a movie in the “artists in action” forum where Caroline delen demonstrates it.
i have in stalled the zapp in to the zsetup folder but the when i go to start up zb it wont" .wat should i do. oh then i remove it and zb doesnt work so i just unistalled it and then reinstalled it ???
it needs to be in the zstartup/zplugs folder. You might need to create the zplugs folder first if you haven’t already.
