zaplink and projection master problems
I used the zaplink tool for texture and every think its Ok until I drop now in the projection master, then somethink very bizar hapens with the texture, see the image, one perfect in the Photoshop the another after I drop from the projection master
You do not use ZAppLink AND Projection Master. You can simply use ZAppLink, which handles the drop and pick up automatically.
Thanks Aurick, it’s true, and faster too, I already working on the the busty , and I realised that the problem whif the texture was that I’m fixing the texture in the perspective form in Photoshop and I have to fix it in ortogonal way, thats why the texture exploded when I return to Zbrush.
Regards
Rodrigo Clemente
What i just realized with some testing, if you model in perspective (because your reference pic in the bkg no doubt has perspective) then press P to goto your orthographic view…
Then load zapplink and select perspective (no fade retains slightly better quality) do your thing, go back in , click fade off and then back on. and it should project without any problems.
cheers
Stu Shapiro
