Z4r2: Insert Brushes' Alt Key Function Conflicts w/ Subtool Selection. [Answered]
I tend to use (and love) Zbrushes alt-click subtool selection frequently, as I rack up ridiculous amounts of subtools, and it’s the only way I can efficiently navigate between them.
Even though most brushes have an alt functionality, it’s not relevant unless you’re clicking over an active tool, so you can alt click on inactive subtools to highlight them without issue.
However, when an insert brush is selected as the active brush, and you alt-click on an inactive subtool with the intention of highlighting it, it activates the insertion behavior, masking out the active item, and sometimes inserting small, extraneous geometry that can go unnoticed and cause problems later on.
It’s not a crippling issue, because you can take care to switch brushes before clicking through your subtools, but it’s definitely inelegant, and potentially problematic, especially as insertion brushes begin to play a more frequent role in a zbrush workflow. Perhaps reassigning of one of these functions could be looked at for the next release.
I don’t believe its something I can keymap, but any other tips on how to avoid this conflict are welcome.
Thanks!
Thanks Spyndel:) Press ALT+SHIFT to switch sub tools.
Conks Head. I didn’t even know you could do that.
Thanks!
You did not know that because it is only in Z4R2. You did, however, have figured out in your first post why it was added:)
Sheezz I was just gonna Ask that…,Thankz!
Thanks Support! I was wondering about this as well. Good to know.
