Hey folks,
I have been using DynaMesh a bit now. The insert mesh brushes work well and allow you to Boolean an inserted mesh to create a negative space. This is great but I want more control. Insert a cube to be used as a pin, inside an limb for 3D print of a figure for example.
I wanted to use a mesh I position to create a Boolean Subtraction, rather than having to manually position the mesh with the MeshInsert Dot brush.
I noticed 3 buttons under the DyanMesh button, just below the resolution control. Labeled ‘ADD’ ‘SUB’ ‘AND’ when I hit ctrl to get info on them the info popup explains that each button works as a Boolean operation, for an inserted mesh. Sadly the buttons do not seem to toggle on or off. When I use the insert-mesh button in the Geometry palette, then press Sub or any of the 3 buttons, when pressed they all do the same 'ADD" operation.
Do these buttons work? and if so How. I really want to be able to insert a mesh of my choosing and be able to use it as a Boolean-Subtraction.
Any help would be great
thanks
-J-B0t
