Z4 plugin issues (solved!)
I installed Z4 and a lot the plugins but for some reason decimation master and UV master dont show up in the zplugs menu. Which sucks because i use them the most and would like to keep my work flow in Z4. Any ideas?
Make sure you have installed them correctly. It’s easy for the unzipping to create an extra folder which them buries some plugin files too deeply. See here for general installation instructions:
http://www.pixologic.com/docs/index.php/Plugin_Installation
Hey Thanks but still no luck. So with UV master i download the file and extract it. I have a folder called UVMasterData_4.0 in it there is the .dll and I also have the UVMaster_4.0.zsc. I placed both in the zplugs folder. That seems right to me and is how i did it in Z3.5. I’m on a PC by the way. though still no luck. I tried taking the .dll and putting it in the zplugs folder and i tried putting the .zsc in the uvmaster folder just to check but nothing happened
nevermind apparently i cant follow simple instructions :stuck_out_tongue:
Zstartup/zplugs not Zdata/Zplugs.
Thanks for your help marcus.
That was going to be my next question. :wink:
Glad you got it sorted.
