z3.5 - brush is acting weird
Hi
I have a problem with for example the claybrush in 3.5.
If I want to paint overlapping folds of a shirt with a masked off belt, the brush seems to notice the normals of the masked object and is flipping arround. It is not possible to paint normaly on the shirt. Something changed from painting in 3.1 to 3.5. Am I right?
Is there a button to switch off masked areas?
Thanks in advance
Kind regards
Hilmar
If the belt is a subtool, simply hide it via the visibility icons in the subtool menu, or enter transparency mode on the bottom right of the viewport frame, which “ghosts” any inactive subtools so you can see them, but their influence over your stroke is ended.
If the belt is simply a masked portion of the same subtool, just hide it ( Masking>Invert>HidePT).
