Z intensity not working in 3.5 projectionM
I’m trying to go through these tutorials,
http://www.cgarena.com/freestuff/tutorials/zbrush/pixozbrush/seb_projection.html
and am confused why when I draw a line across a box in projection master I am able to move, scale, rotate it, effect the draw size but I just cannot effect the Z intensity. This seems to only be an issue in 3.5, I tried it in 3.1 and it works.
Any idea what’s going wrong?
ZBrush 3.5 R2 does not update the viewport when you have a stroke in transform mode and then change the Z Intensity. The solution so far is to either disable and then enable Zadd/Zsub or click somewhere on the canvas. This will update the stroke to show the new Z Intensity.
Thanks for clearing that up
I had the same problem, was very frustrating :wink: Glad i found this post. Thanks
