Hi all, in a few hour this image is going on the forum and then come back at home(sigh )i reworked this image, i hope this time all ok. :rolleyes:
Is dedicated to ANDRESELOY and BICC39 for your kind words.(is one for each ).
Credits to Dorian Cleavenger
I’ll post later a little tutorial
Bye
Leo
COol!
All gears up
nice work Marciani as usually.
and better without the tatoo…
Very Nice, good work on this one…
Is the human make in Zbrush?.
Matellic like the feeling of her lips…Vulgarity as the product of her youth…Pain in sight of the future!!..
I love this work very much!!! exellent modelling of the girl…comopostion is well balanced and very well though out…great respect in your direction marciani
Kircho
Hi Leo
You are a mono maniac of Dorian Cleavenger
Pilou
Pilou you are in right!
Bye
Leo
nice one, ouch
Thx guys
To FOUAD:like just explained in renderosity gallery "I want create a ghothic athmosphere, a little bit surreal, with pain and other stuff, at last i seen the head to much white and i’ve put this tatto, in this case is better than a peace symbol i think, by the way if an image reach the target, in my case i want an hard image, i reach my target. No politics, no fans of this period… I speak english not well, if difficult for me explain… "
To Q.QEo: Is made in Lightwave
Marciani my friend, no problem with me
I know that is only artistique meaning.
as I said before, really nice work as usually.
Italian is of excellent artists and designers, and your creations confirm your origins
To fouad:
Well tailored.
Thanks Boozie…
Which honor, i love your works man…
Very different very relaxing, the opposite of mine
Bye
Leo
Hi all, like usual i post some info about this image, probably you know this simple step, i hope can help someone at begin.
:small_orange_diamond:Size rendering 3300*2400 (like just say,is very instable at big size resolution, then you obtein all with spending so many time more,BECAUSE YOU NEED restart restart restart :angry:
:small_orange_diamond:8 layers: i prefer put the object and work around in more layers, in this way i change easy everythingh (obviously depending on your CPU power).
[img]http://www2.zbrushcentral.com/uploaded_from_zbc/200405/user_image-1084088421imj.jpg[/img]
:small_orange_diamond:Girls made in Lightwave and posed with bone
:small_orange_diamond:Start you project with the plane and wall in a separate layer, in this way you can put everythingh up without every time if you did an error restart the whole project.
:small_orange_diamond:Think in your mind wich is your project, this save so much time, where you are uncertain, make a new layer, but you can't do 1000 layers :D
:small_orange_diamond:positioning the obj and attribute for each of one a material and save the name in a folder, in this way quickly you are able to change color.
:small_orange_diamond:Use MM tool but warning, sometimes are very unpredictable.
[img]http://www2.zbrushcentral.com/uploaded_from_zbc/200405/user_image-1084088931emo.jpg[/img]
:small_orange_diamond:Often like a drug we tryng to do everythingh in a poligonal way(2.000.000 and more)but sometimes it's more easy and efficient utilize the 2d tool.
:small_orange_diamond:With the body put on the canvas with this material
materialscene.zip
lights setup.zip
paint over with layer brush vith Zadd and make the wrinkle with simple brush with Zadd or sub (chose the leather material)
[img]http://www2.zbrushcentral.com/uploaded_from_zbc/200405/user_image-1084089679zxa.jpg[/img]
:small_orange_diamond:To obtein this effect put the ring or what you prefer in another layer, positioning and the came back in the body layer and with Zadd simple brush ADD some deep and refin With Zsub the hole.
[img]http://www2.zbrushcentral.com/uploaded_from_zbc/200405/user_image-1084089830gor.jpg[/img]
:small_orange_diamond:I've used the same technique for the gloves paint over with a leather material and after change the deep again and make the refiniture.
Use some alpha like stencil and add a crack and wrinle around
Stocking are painted dirctly on the leg with another material. I’ve used a square grid alpha and i’ve used this like a stencil in a wrap mode.
Skirt are in the last layer, render all the layer(without this skirt layer), with the Flatten button uncheck, bake the results,now with only baked layer switch on the skirt layer and render again.
Hope you help
Bye
Leo
Dear marciani,
thank you very much for explain of your layer-technique — very useful
(great forum and peopleZZ here
Cool man. Love the female model. Thanks for the walkthrough.
