Z 4R2 noise problem
Hello. I have question about zbrush 4r2 the Surface noise funcition. When I preview it on mesh everything looks fine but once I press apply to mesh everythings kinda inflates. Any idea why that is?
I find you have to accept that the noise will be exaggerated somewhat once you hit apply to mesh. This is less of a problem if you have enough subdivisions. Whenever I apply noise I use -.0001, not the default -.0007. if I want more I apply it twice. Also note that the larger the noise the worse the problem, so try a setting between say 80 - 150.
thank you for your advice
