Hi all! after doing a bit of studying of other peoples shaders, and tweaking a few of my own here is what I have come up with…:
and here is the material:
Polaris-Ink.zip
Special thanks to Fouad B. and Aurick for the above shader…I used a method they described a long time ago to get above shader.
And here is another one for color models to get a comic book like appearance, you need to use enclosed lighting to make it look proper :
this shader I made myself tweaking materials…
ALL of the above shaders need to be Rendered to see them… they look terrable untill you render them!
so be sure to press the “Best render” Button in the material browser…
Both materails exploit the Cavity shader to give the detail outlines… tweak cavity settings for best results
remeber to best render to see your tweak
I realy enjoy the first toon shader the best, it gives a bit of a shadeing effect to the inside of the models
PLease feel free to post your tweaks here or images you make with them
hopefuly we get some nice toon shaders for Zbrush from experement
Have a good one everybody
