Hello.
I tried to use an insertmesh brush on a plane with wrapmode set to 2.
Sadly the meshes were not repeating on the surface at all. Although all the non-insert-mesh brushes did.
Is there a way around my problem?
Thank you.
Hello.
Thank you.
InsertMesh brushes will not work with WrapMode - it is designed for tileable alphas.
You may find these videos useful:
http://pixologic.com/zclassroom/homeroom/lesson/environments-with-tate-mosesian/
Well… The guy the video could actually use some wrapables insermeshes…
Thank you. This helps.
