HI guys ,
i’m going to install zbrush4r2, i am just wondering can i revert back to zbrush4 if theres anyproblem occurs?
if so , how do i do this. Reinstall zbrush 4 installer ?
THanks guys
HI guys ,
THanks guys
You should not deactivate/uninstall ZB4 prior to R2 installation. R2 installs separately , and both programs can still run, just not at the same time.
Win-win.
Thanks Scott
Great THanks for the tips ! cheers !
I actually needed to run both Zbrush versions, 4 and 4R2 because of some troubles I have had with layers just to check things. They are both able to run at the same time on my Mac Pro 8 Core!
Your rite ! i can run both tooo… when i’m not sure of things i’ll revert back to 4 … i hope tat i’ll get using r2 more often now … thanks guys!
