Working ZBrush on Linux
Hello.
I’m trying to get Zbrush 2021 working on linux and almost got it working.
My operating system is Manjaro MATE, I use portProton, it is more convenient to configure everything in it and the speed is impressive.
But I have a problem that prevents me from using Zbrush to its full potential.
I use an XP-PEN Deco 03 graphics tablet, the Linux drivers are installed and everything works fine in native applications.
But Zbrush works through Wine (which uses portProton) and pen pressure doesn’t work for me correctly.
When opening Zbrush, if you select a base project, for example, a “cube” and draw on it with a pen, then the pen pressure works properly, BUT, once you click the mouse, after that the pen pressure stops working.
I tried to find a solution to the problem, but I did not succeed, I did not find people who have this problem.
For interest, I installed Lutris and there this problem is observed in a different way. Within the window, you can click with the mouse and the pen pressure will not disappear, but if you try to open any of your projects, the pen pressure immediately stops working.
Please tell me how do you deal with the pen pressure problem in linux ?
A post was merged into an existing topic: Using Zbrush on Linux
