Workflow help needed for inflating 2d plane into 3d mesh
I am trying to find a good way to create an inflated mesh starting by a 2d image, keeping it simple and rounded for easy 3d printing. I know that a very good way to go is to generate the mesh with Adobe Photoshop 3d Extrude tool. like in this video http://vimeo.com/60953547 and its website http://crayoncreatures.com/ ; and since I don’t have the 3d tool in Photoshop I wonder which is the best way in Zbrush to replicate the same effects.
I found a way by cutting a 2d plane accodingly to the projected 2d image and then inflate baloon some specific area , then dynamesh and mirros and merge. But the workflow is much more “dirty” then the “Photoshop way”
Another way is to simply use zshpere , and this is good but quite longer.
Would you like to give your suggestions and advises…that would be really appreciated. I am going to post a video soon to show what I did so far …
Can’t wait for your replies
Kind regards
Guido
http://docs.pixologic.com/reference-guide/alpha/make-3d/
Hi Doug Jones,
thank you for your tip. I confess that I already tried this method ( Alpha Make 3d ) and it is good and requires a bit of extra work and quite unpredictable.
  1. If you use a 100% black and 100% white mask , you will have a general fixed elevation of the resulted mesh. For a rounded shape you will need to increase the smooth value and decrease the resolution.
  2. Or create a proper alpha gradient from the beginning in Photoshop. Which is a blind work…
I am sure there an easier way… still investigating
Thank you.
Regards
Guido
Did you try to adjust the alpha in the alpha palette with the modifiers? :wink:
yes I did try… maybe I wasn’t enough patient working on the curve setting… I will give it a second try.
Thanks
Guido
http://youtu.be/IdMNKK9zvxA
As said, above there is my latest workflow solution. I was thinking to use also the 2,5d canvas … not sure if this would simplify .
Please let me know how I can improve this workflow, that would be great.
Regards
Guido
Try projecting it on one wall of a shadowbox and add the roundness yourself in the other views?
