Wire frame help.
Hey probably a noob question but I cant figure out how to display my low poly wire frame onto my high poly.
  • Go to subdivision level 1
  • SHIFT+F to enable Frame Mode and see your base wireframe.
  • While still in Frame Mode, go to your highest subdivision level. You should still only see your base wireframe. If you turn Frame Mode off then on again you will see the dense, subdivided wireframe for the high res mesh.
cool cool thanks a lot man
the image that you’re showing isn’t from Zbrush.
it was rendered in Max I believe with a composite material. I think he uses max…but I don’t remember.
