Hi.I am trying to create a wing.Some wip here comments will really helpfull…
Your feathers have good detail, but all of your feathers look the same, just scaled larger or smaller. An actual wing has different types of feathers.
I’d suggest you use some reference images, but you are off to a good start.
Ya it’s looking pretty good. It looks like you are using projection master for the bulk of the wing with mesh insert for some of the feathers on the edge? Just curious. I’ve tried a similar technique and your version turned out way better than mine did.
I think you’re off to a great start. I’d agree about switching up some of the feathers as well as looking out for where some of the feather intersect/overlap.
I’ve also made a wing using the new zscketch zspheres. Using the different depth zsketch brushes to represent the different rows of feathers. It looked nice but is probably suited for wings seen at a distance as that technique alone doesn’t bring the detail you have here.
thx for the comments and yes you are right…with this technique all smiliar and you really forcing your system with merging all feathers.but anyway it is a trying,better one is sculpting instead of this one.did this one for better details but detail inst ewerything…again thx for comments will study for sculpt.
If it’s really taxing your system you might try decimating the feather ztools before you start meshinserting them.
The feathers look somehow thick. You might want to reduce their width
