Why Holes in Mesh after CTRL Dragging 2X?
Hi, I used Insert cylinder brush on a dynamesh plane. I then CTRL + Dragged 2X to join the mesh with the plane. Then I inserted a second cylinder and again selected CTRL + Dragged 2X to join the mesh with the plane, but the second time I did it created holes in my mesh. Do you know why?
Dynamesh doesn’t work OK with shapes without enough thickness and this could be the case.
Ok, Altea, thanks for the reply.
maybe I could create a thicker plane and then when I’m done use the trim dynamic tool to make it thinner again.
