Why does fibermesh look like poop the shorter you make it?
I’m trying to learn it and if I apply it at default it looks fine but if I shorten it “close” to the underlining mesh it looks really bad. This is w/o messing with any settings except for the length.
How you make them shorter? With the length setting at creating or with a brush? Can you include screenshots?
With the length setting. I’ll try to get some SS. The first render is default and the hair looks good. The second render has the hair looking more clumped and not thinned.Untitled-1.jpg
By default fibers have no textures. You probably have loaded a template that is not optimized for short hair of the kind you want. Starting with the default fibers would give you a more neutral starting ground.
Thanks. Will try that out.
