Why do my normal maps not show up...
I create the normal map it shows up on the right, which is good.
Now how do I export it? It does not show up in my texture palette.
That is how it is supposed to work right?
Because it does not show up I can’t export it, help!
You’re using ZBrush 3.2, right? After creating the normal map, click Tool>Normal Map>Clone NM. This copies the map out of the Tool palette and into the Texture palette where it can then be exported.
The same holds true for textures and displacement maps. All must be cloned out of the Tool palette before they can be exported. It’s due to the fact that 3.12 and above apply maps individually to each SubTool.
Thank you!
