Where to find "GoZ_KeyShortcut.cfg" ??
I have a problem installing GoZ for Modo (windows and ZBrush4, Modo 64 bit).
If I go to preference/GoZ/ force reinstall: it does not allow Modo (unselectable).
If I chose “Path to Modo”, it tells me that I need to install some files manually because Modo is not installed in the default folder ( I use a specific partition for all my programs ). Those file are gozio.lx, GoZ_Cat401.cfg and GoZ_KeyShortcut.cfg. But I can’t find GoZ_KeyShortcut.cfg.
I had some reply over at Luxology forum but it seems no one has this file… So why does the instructions ask me to install it?
Actually, I found the GoZ button and it works fine.
So I’ll just ignore the error message and the innexisting file.
