where is the move vertex on the zbrush 3
:frowning: Hello all
I had learn to move vertex on zbrush 2, but when I go to zbrush 3, I am not able to move vertex with move button no more please tell me is there anyway I can do it on zbrush 3.
Reduce your brush size to 1 and use the move brush. Turn on ‘Frame’ to better see what you are doing.
Hope this helps.
As Jaxx said, it’s now a brush (found in the Brush palette). This makes room for the old Move to become part of TransPose, and it also gives Move access to all the different brush modifiers.
Also if you set your focal shift fairly low you can move small amounts or even single vertices for more control over the move brush. Handy tip for working at lower subdivisions :smiley:
