Flare: Locally increases or decreases the width of the each Fiber so that it has a wider tip or root. The position of the Flare is determined by Flare Center (below).Flare Center: Defines the location of the Flare on the individual fibers. A positive value will increase the size of the tip while a negative value increases the size of the fiber’s root.
Flare Exponential: Defines how the Flare progresses along the segments making up the length of the Fiber. A low value will define a fast progression of the Flare while a higher value will Flare progress more gradually along a greater portion of the fiber’s length.
