Where do you place models so they apear in the startup menu?
Where do you place Models so they show up in the start up menu? example the Dragon or the Posiedon. I would like to see them in my startup menu.
Also, is there a way to have startup Matcaps that wont bog Zbrush startup? Or do i have to load them individual as i need them? I am used to having a complete library as i model. Like Max for example. I wish to add all of the Matcaps that are made available in the down load section.
thank you in advance!
:slight_smile:
anyone have an answer to this one? i have seen them listed in the tutorial videos. but they never explain how to set them into the startup. I am currently using 3.1
I’m pretty sure the default tool set comes from Zbrush3/Ztools for ZB3.1. For ZB3.5 there is a new interface (lightbox) which will show you the contents of this directory by default.
For Materials, in ZB 3.1, I think you pretty much use Zstartup/Materials if you want them auto-loaded. In ZB 3.5, lightbox will show you the Zmaterials folder so you can load them as you need them.
For ZB3.1 you might want to grab the alpha/texure loader from the downloads center: http://www.pixologic.com/zbrush/downloadcenter/zplugins/ It lets you browse your texture and alpha collections without loading them all at startup (Zstartup/Textures and Zstartup/Alphas)
