I upgraded to Zbrush 4rc and I can not use spotlight, does anyone know what may be causing this and how to fix it?
You import your texture via ‘Texture’ menu then click ‘Add to Spotlight’ button.
Spotlight is turned off by default. To load an image go to the texture pallet and import or double click one in Lightbox. By default it loads as a texture; in the texture pallet go to the Spotlight icon and click add to spotlight. From then on any image you load as a texture will be added to spotlight.
That is how I did it in Zbrush 4 for sure, however, when I select a texture the spotlight option is not even there?
Thank you all very much, that was it for sure.
i was looking a long time ago for this spotlight, so thank you man you saved me
