whera are the Row/Col/Grd commands?where are the Sel/Skp settings ?
tool> masking
Intens: The strength by which masking is removed by the Row/Col/Grd commands. Use different Sel/Skp settings with different Int amounts to vary masking strength on different parts of the object. Default is 100%. Range is 0% to 100%.
Blend: The degree to which a new masking operation mixes with an existing mask. This lets you, for instance, combine a Row/Col/Grd mask with an Alpha mask. To use, create a mask, then set the Blend amount, and then apply a second mask, and so on.
Intens: Blend: how to use it ?:rolleyes:
The Row/Col/Grd and Sel/Skp commands are only available for parametric objects. Polymeshes can’t use those commands due to the fact that they don’t have a mathematically predictable structure, which these features depend on.
As for Blend, you need to mask the model. Then set the Blend value. The next mask that you do will blend with the first.
thanks a lots!
