Could someone please tell me why the toes curl on the ‘average man’ ( in tools section of lightbox) when you try and use a brush on them…say for instance clay buildup…?
Probably because you’re pulling too many polys from behind and around those fine detail areas with your brush falloff. Try using smaller brush size, zooming in closer to work, and turning on Backface Masking in the Brush>Automasking menu.
Also, the clay brushes work best with medium to high polygon resolutions. The Super average man is somewhat low poly by default unless you subdivide it.
Thanks once again !!!
I have so many questions…now I know what its like to be one of my students !!..
sorry !..where do I find brush automasking menu please ?..
No problem. Brush> Auto Masking> BackfaceMask
thanks…your advice cured the problem !!
