a tutorial about how that was done would be fantastic
absolutly wounderful work
well done !!
well done !!
…why no sound with this incredible beast ?
Pilou
…Oh god… how he do it that…???..
…I can do same…snif…
Ive just noticed the rib cage section of the model and was wondering if this was a morph target or something special in XSI ?? do tell …
Hello , sorry be late , im totally busy at job , i post some image that i hope with be helpfull , i have try to explain a bit how my procedure , if you get any other question dont hesitate . sorry this is maybe a bit more xsi then Zb , i hope it ok .
sumpm1 - look for tension map(tensionmap.xsiaddon) on www.xsibase.com i think its what you want .
Frenchy Pilou because im a modeler and not a sound editor
tranimatronic its some animated displacement map , i post image now to explain it .
AMAZING WORK…animation is perfect and muscle bulging and veins are well done…wish if this was done in Maya
That clip was amazing, really really cool!
I have just made a plugin to allow you to do this kind of animation in Max very easily. Check it out
Hi this is the best forum i have ever seen. I saw that werewolf anim quite a while ago and when i set about making a model for my first attempt with zb it was with that inspiration in mind. Then, not only do i see this on my first day on the forum, but someone chucks a max plugin into the mix to help make it happen. Its amazing. I just wanted to say so. Great forum.
