Hi all, I am stuck with another problem in which I exported my model from zbrush to maya at subdivision level 1 to create mouth opening to create inside teeth and tongue. I used split edges and extrude to create mouth bag and then used clean up. When I’m done I exported model in .obj format and imported in zbrush then pressed “Yes” in the warning message to transfer high resolution detail to modified mesh.
But I got totally weird result when I pressed yes. I have no idea why this is happening but I have double checked my model in maya and repeated same step of creating mouth bag and imported in zbrush but same result. Any guess of solution to this problem? Here is the screen shot.
