I connect zsphere carefully. when i bush “A” …
It show me some thinig that I don’t expect.
there is a problem with retopology when you try to make something like a finger with only four sides, the only solution is to add an extra loop. you can also not make the fingers in retopology but extrude them using the edgelooping function in the geometry palette.
OK i understand. thank’s a lot !
I 'll avoid this kind of zsphere connection.
