Weird OBJ export problem
I have a very weird OBJ export problem. I have made a model in ZBrush and export it in OBJ format so that I can import it in another application, Strata CX7 in my case. But as good as model looks in ZBrush it appears completely distorted in Strata. Please see close-up image, left is distored OBJ as it appears in Strata, right is ZBrush. I have never had this problem before in my workflow, but what is this? I feel hopeless… what is going on here and what can I do?
can you show your export setting?
Sure, here they are:
1.try Mrg off and separately try
2.flip option on
I tried this but nothing works… same problem.
I solved the problem by splitting the object in 2 (using the masking tool), then export each part as an OBJ and combine them again in Strata. This works and the strange distortion is gone. Unfortunately I have no clue what caused the problem in the first case…
