win tab service not available. This is what i get when i start and end the zbrush 3.5 r3 version. anyone getting this?
Uninstall then reinstall the latest Wacom drivers. If this doesn’t fix the issue or you don’t use pen tablet, then look into disabling any pen tablet services. Also do a search here for the issue there’s been a couple of threads, or even google it, it will lead you back to this board with some older posts about this.
I see this one a fairly regular basis, but them I’m stuck using Vista/32.
I have the latest Wacom drivers, but still see the problem.
Not frequently. just often enough to be irritating.
I simply reboot, it’ll always work afterwards. Clearly an OS/Driver issue.
G.
Thank you. I went to the wacom site and downloaded the update software and all is currently good. Thanks again.
cheers.
