Weird and strong Artifacts during polypaint
Hi guys,
My first post here, but been is zBrush since version 2…Normally I find solutions with the search function on the forum, but couldn’t find this specific issue. But i might of missed something :wink:
I have attached an image that shows the problem during texture painting, its like JPEG compression artifacts problem, normally this popes up after re opening the file (the next session after i close ZBrush) and its worse when you go on a higher lever (subD).
Normally I notice this when I am painting on the lower subD level and more up to the highest…Depends on the severity of the problem, some cases are worse then others…
I hope I am doing something wrong…and its not a weird gremlin bug…Any info or insight in to this issue will be much appreciated…as I didn’t have this issue on previous versions…
Many thanks
IvanG
