Way to rotate whole zscaffold or change initial zsphere?
Hey guys. I wanted to do a little more work posing and I was wondering if there was any way to move the whole mesh (rotate etc) or simply change which zsphere is the center, so I can rotate the parts I need. Cause I have the initial sphere at the chest, so It’s kinda hard to rotate the hole upper body.
Hope that makes sense!
Thanks!
A way to rotate the whole mesh is to get out of edit mode and use rotate and then you can rotate it all with the gyro tool. Same applies for move and scale and once you are done you can get back to edit mode ir then again do some more manipulations out of edit mode and reenter edit again etc Hope this is what you want.
Hey thanks for the help! It’s not exactly what I’m looking for :P. When u exit edit mode and rotate,move,transform, it doesn’t keep those transformations when you go back into edit mode.
Basically I was wondering if the initial zsphere can be moved at all while keeping all its children in order.
Thanks in advance!
