Hi all i was making setting for my Zbrush 4 i made the same setting i use in Zbrush 3.5 but somehow when i was trying to set the subdivision level on wacom intuos4 touch ring i notice some bug when i subdivide the model the maximum level The touch ring works well but when i try to reduce to the minimum level the subdivision jump back to the maximum level, there’s must be some bug on the value control between 1 and -1 i also made some test on photoshop cs5 Maya 2010 and zbrush 3.5 but look like my wacom is fine works great i guess is some zbrush 4 bug.
If anyone have the same problem please replay my. Thank you.
