Visible polygon edges
Hello all, how do I make these edges disappear in my viewport ? Ive tried different materials, but no avail. This is supposed to be full white colour, but I can see the poly edges.
See bottom. http://docs.pixologic.com/reference-guide/tool/zsphere/display-properties/
Increase subdivision level. Zbrush’s main strength is that it can comfortably handle more raw polygons that most other programs. This is especially important if you’re polypainting, as it looks like you may be.
There is a render time setting that will smooth poly edges to an extent, but while working in the viewport, your best option is to subdivide further.
Some matcaps highlight poly edges to a greater degree than other materials.
