Views not saving/loading properly
Hi guys,
Forgive me if this has been brought up before.
I want to save my views - front, back , left, right. The front view keeps flipping on the z axis for some reason. When I do a ‘clear to’ and fix it then save views again, it lasts in the session I have open. I can cycle through front, back , left, right no problem - but when I open the file from scratch and load the views I had saved, it goes back to the flipped front view. This is driving me mad!
Does anyone here have a solution to this?
Thanks
This might help>> http://www.zbrushcentral.com/showthread.php?161588-quot-Axis-quot-Plugin-for-ZBrush-4r2
Thanks so much for replying Doug, I will check this out.
Cheers
This worked perfectly, exactly what I needed!
Thanks again Doug.
You’re quite welcome. Maybe someday, the feature will be ‘built in’. Hoping…
You would think it would be built in seeing as though the actual one built it doesn’t work!
The fact you don’t have to save the views out is great too.
