Hello, all.
It’s been a month since I started learning Zbrush.
Before, I’ve been using 3DS MAX for a few years.
So, as you may know, it’s quite confusing when it comes to navigate around the canvas. Especially zooming with Alt pushed then released, etc… I have 2 questions.
In the 3DS MAX, there’s a “viewport undo” command which is Shift+Z. Is there any in Zbrush to revert the canvas change? (so you can undo your last zooming)
Also in the MAX, if you push “Z” (similar to F to set frame to cover a whole object in Zbrush) you can directly go as close as you can to the editing surface. Is it possible to do the same in Zbrush ?
Well, thank you for reading. And this is still an amazing tool !!
