viewing a painted texture on model from photoshop
i want to view a texture from photoshop on model in zbrush. What i really want to do is paint a low poly game model in zbrush. Is this possible?
You can import the texture into the Texture palette and then use the Tool>Texture Map menu to select the texture and apply it to your model.
To paint a texture, you start with polypaint. When done polypainting you can then convert the polypaint to texture. This is explained in the online documentation and the Getting Started guide (see my signature).
ty as always aurick. I got it working. I do a lot of low poly organic creature stuff so this is a big help in texturing that.
You can also use Projection Master to paint directly onto the texture after it is applied.
