So there’s a bunch of files you can save out and I just want to verify what each does and how they corresponds to one another.
VMEM
I’m aware you can redirect the vmem folder, but is it also safe to delete the files inside?. I’m assuming they correspeonds to older sessions of zbrush, is this a correct assumption? Are they used in conjunction with any other feature in zbrush so erasing those will have strange effects later on?
PROJECT FILE
The project file can save history in a separate file and can get pretty big, but sometimes I save one out to be able to go back and create movies of the scuplting process later on. However, it seems that it saves all history for each tool and not only for the one I had selected. Is there a workaround for this?
The project file, does it store the tool itself or does it load it from the separate .ztl file? if not, is there a need for the .ztl file or should I just keep saving the project where I have the undo history.
TOOL
Can you unload tools? I usually save out some versions of my models and then load them in to view the progress, perhaps cleaning the last one up, deleting unwanted meshes and appending them to the earlier version in case I’d need another pair of shoes at a different time and place.
After many tools have been loaded the screen estate becomes pretty cluttered and I’d like to unload them once I’m done and don’t need them. This would also solve the huge project file issue I’m experiencing.
DOCUMENT
What is this and when and why do I want to save the document?
I’m hoping I’m making myself clear enough for you to understand my questions.
Have a great day everybody!
