Uv's?
Hi, I am an idiot.
I did my sculpt and polypainted it, and now I wan to export a displacement and texture map. Once I get an okay result the other time not as good. Please tell me what I’m doing wrong? How to reorganize the uv’s? Why do they get screwed up in the first place? Is it okay to read in the multi displacement 3 under get mesh info tile:0? or does it have to say tile:1? How is that accomplished. My models are either red or black.
This is the example, 1 is one type I get, and 2 is another, is one of them wrong, or atre they both ok? Same thing with textures, it’s a lottery pretty much, and I don’t want it to be.
I’ve gone through pixologic manuals, and a lot more, so don’t know if iit’s a languge barrier or I’m as sharp as a spoon, but please make me sharp :confused:
Thanks,
cr
[[attach=151694]example.jpg[/attach]](javascript:zb_insimg(‘151694’,‘example.jpg’,1,0))
At some point you use the Tool>Texture>UVTiles button. This remapped the model to UVTiles mapping.
To return to the original mapping method, go to level 1 and import the original version of your model again. This will restore the original UV’s.
Thanks for replying aurick! So UVTiles read under the adaptive uv tiles if I applied them on top? The thing is actually that I do not have the original model, just this one. And if I export to obj and open it in max for uvw unwrap and import it again to zbrush, the subdivisions are all a mess, spikes in all directions :frowning:
