UV's isn't exported from Zbrush?
Hi! My UV-map isn’t exported with the OBJ from Zbrush.
I created a polysphere in Zbrush 3.12B (mac), exported the “SDiv 1” version as an OBJ. I edited the UV-map in Cinema 4D and then exported it back to ZB.
I tested it in ZB by clicking “New from UV Check” in the Texture panel and the UV’s seems fine (I get a grey UV texture looking like it did in Cinema).
Then I created a normal map and exported the Ztool (SDiv 4) as an OBJ again and when imported in Cinema the UV’s aren’t there?!
I’ve used “Export” in the top of the Tool menu and I’ve also tried the different settings in the “Export panel” in the bottom of the Tool menu.
Anyone who know why the UV’s isn’t saved with my model? (the same procedure has worked before)
Many thanks in advance!
// tennet
There isn’t any reason why ZBrush wouldn’t be exporting the UV’s unless you had at some point clicked Tool>UV Map>Delete UV. Maybe a setting in C4D is deleting them on import?
