Dear Zbrushers,
When I unwrap a male humaniod model it mucks up. I’ve been able to use Zbrush t o Unwrap it.
Is it because the models mouth is not only open, but has an enclosure (i.e. cavity). I say this because of the all the models I see have their mouths closed.
Nonetheless, I have tried several attempts to correct the poor UV fittings that I get when I apply a checker texture. I’ve tried color painting the areas where I should get seams, etc, but the Zbrush Plugin is unable to correctly sort it out. Hence I feel it may be due to the mesh having an enclosure.
What I mean by “enclosure/cavity” is that the mesh, which is all intact btw, is simply the mouth cavity. The lips are not touching.
Hope this can help.
kind regards,
Ash
