UV problem
Hi Guys,
I have a problem, when I export a model from max to zbrush with the uv's already, and bring it back to max i get this, all the uvs i already did bedore is split it into polys. If someone can help me to solve it, i will really appreciate it. Sorry for my bad english.
when in zbrush under exports make sure “Grp” is turned off and then check the “Mrg” button now you should be fine! :slight_smile:
Thanks a lot LYNXY, now is working perfect.
Many thanks.
Diego.
