Uv missing?
I have just started using zbrush and while following a tutorial found that the uv setting under textures isn’t there. :cry: Any help? Thanx to all that can!
If it’s a ZSphere preview or a parametric/primitive object you need to convert it to a polymesh. Press Tool>MakePolyMesh3D and then select the newly-created version of the model in the Tool palette.
